Ga door naar hoofdinhoud
HTC Flyer Back Cover Replacement
Wat je nodig hebt
    1. HTC Flyer Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 3 HTC Flyer Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 3 HTC Flyer Back Cover Replacement, Back Cover: stap 1, afbeelding 3 van 3
      • Apply pressure along the bottom of the white panel containing the camera and push upwards.
      • It may take some effort, but it will smoothly slide off.
      Vraag FixBot
      Voeg opmerking toe
    2. HTC Flyer Back Cover Replacement: stap 2, afbeelding 1 van 3 HTC Flyer Back Cover Replacement: stap 2, afbeelding 2 van 3 HTC Flyer Back Cover Replacement: stap 2, afbeelding 3 van 3
      • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
      • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
      Vraag FixBot
      Voeg opmerking toe
    3. HTC Flyer Back Cover Replacement: stap 3, afbeelding 1 van 3 HTC Flyer Back Cover Replacement: stap 3, afbeelding 2 van 3 HTC Flyer Back Cover Replacement: stap 3, afbeelding 3 van 3
      • Remove the black protective piece of plastic by sliding it upwards.
      • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
      • A center 3.5mm Torx screw will be covered by "VOID" sticker.
      • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
      • Remove the protective panel by sliding it upwards.
      Vraag FixBot
      Voeg opmerking toe
    4. HTC Flyer Back Cover Replacement: stap 4, afbeelding 1 van 2 HTC Flyer Back Cover Replacement: stap 4, afbeelding 2 van 2
      • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
      • Use a plastic opening tool to lever up the top half of the cover.
      • Lift the back panel up and remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Justin Funk
485 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-5, Leahy Fall 2014 Lid van USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 755
