Ga door naar hoofdinhoud
HTC Droid Eris Battery Replacement
Wat je nodig hebt
    1. HTC Droid Eris Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HTC Droid Eris Battery Replacement, Battery: stap 1, afbeelding 2 van 2
      • Place the device on a flat surface with the headphone outlet/jack facing away from you.
      • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
      • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
      Vraag FixBot
      Voeg opmerking toe
    2. HTC Droid Eris Battery Replacement: stap 2, afbeelding 1 van 2 HTC Droid Eris Battery Replacement: stap 2, afbeelding 2 van 2
      • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
      • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
      • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Elizabeth Ofori
648 Reputatie
6 handleidingen geschreven
SUNY Cortland, Team 1-2, Getto Spring 2013 Lid van SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 1,128
