Ga door naar hoofdinhoud
HP w2216h Control Buttons Replacement
Wat je nodig hebt
    1. HP w2216h Control Buttons Replacement, Control Buttons: stap 1, afbeelding 1 van 1
      • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
      • Remove the four 12 mm Phillips #000 screws on the back panel.
      Vraag FixBot
      Voeg opmerking toe
    2. HP w2216h Control Buttons Replacement: stap 2, afbeelding 1 van 2 HP w2216h Control Buttons Replacement: stap 2, afbeelding 2 van 2
      • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
      • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
      • Stand will easily pull off.
      Vraag FixBot
      Voeg opmerking toe
    3. HP w2216h Control Buttons Replacement: stap 3, afbeelding 1 van 3 HP w2216h Control Buttons Replacement: stap 3, afbeelding 2 van 3 HP w2216h Control Buttons Replacement: stap 3, afbeelding 3 van 3
      • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
      • Turn monitor so that the screen is facing you.
      • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
      • The best places to pry are in the lower left and lower right corners of the black bezel.
      Vraag FixBot
      Voeg opmerking toe
    4. HP w2216h Control Buttons Replacement: stap 4, afbeelding 1 van 1
      • Lift the screen assembly from the plastic housing from the corners.
      Vraag FixBot
      Voeg opmerking toe
    5. HP w2216h Control Buttons Replacement: stap 5, afbeelding 1 van 1
      • Remove the plastic buttons from the contacts
      Vraag FixBot
      Voeg opmerking toe
    6. HP w2216h Control Buttons Replacement: stap 6, afbeelding 1 van 2 HP w2216h Control Buttons Replacement: stap 6, afbeelding 2 van 2
      • Remove the wire connecting the contacts to the screen assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick Aucoin
221 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-1, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 822
