Ga door naar hoofdinhoud
HP iPAQ H3850 Buttons Replacement
Wat je nodig hebt
  1. HP iPAQ H3850 Buttons Replacement, Buttons: stap 1, afbeelding 1 van 1
    • To begin the disassembly of the device, place it on a flat surface with the screen facing down.
  2. HP iPAQ H3850 Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws found on the back cover of the device.
  3. HP iPAQ H3850 Buttons Replacement: stap 3, afbeelding 1 van 2 HP iPAQ H3850 Buttons Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the back cover using the plastic opening tool against the grooves along the sides of the iPAQ.
    • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
  4. HP iPAQ H3850 Buttons Replacement: stap 4, afbeelding 1 van 1
    • Remove the ribbon cable connected to the display motherboard by pulling the plastic clips on both sides towards the top of the device.
    • Use a plastic opening tool to carefully pull the brown ribbon cable from the connector.
  5. HP iPAQ H3850 Buttons Replacement: stap 5, afbeelding 1 van 3 HP iPAQ H3850 Buttons Replacement: stap 5, afbeelding 2 van 3 HP iPAQ H3850 Buttons Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to carefully remove the display motherboard from its housing.
    • Unplug the connector from the opposite end of the display motherboard.
    • Completely remove the component.
  6. HP iPAQ H3850 Buttons Replacement: stap 6, afbeelding 1 van 2 HP iPAQ H3850 Buttons Replacement: stap 6, afbeelding 2 van 2
    • Remove three small screws from the corners of the motherboard using a Phillips head screwdriver.
    • Use your hands or plastic opening tool to carefully lift the motherboard out of its housing.
    • Remove two screws from the silver cover using a Phillips #00 screwdriver.
  7. HP iPAQ H3850 Buttons Replacement: stap 7, afbeelding 1 van 3 HP iPAQ H3850 Buttons Replacement: stap 7, afbeelding 2 van 3 HP iPAQ H3850 Buttons Replacement: stap 7, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the two screws at the bottom of the device.
    • Use a plastic opening tool to remove the button motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 243
