Ga door naar hoofdinhoud
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
Wat je nodig hebt
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: stap 1, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: stap 1, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: stap 1, afbeelding 3 van 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: stap 2, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: stap 2, afbeelding 2 van 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: stap 3, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: stap 3, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: stap 3, afbeelding 3 van 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: stap 4, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: stap 5, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: stap 5, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: stap 5, afbeelding 3 van 3
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Clement Cheung
643 Reputatie
5 handleidingen geschreven
Cal Poly, Team S18-G5, White Winter 2019 Lid van Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 1,967
