Ga door naar hoofdinhoud
HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement
Wat je nodig hebt
  1. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: stap 1, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: stap 1, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Batteries: stap 1, afbeelding 3 van 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: stap 2, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Shell: stap 2, afbeelding 2 van 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 3, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 3, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 3, afbeelding 3 van 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 4, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: stap 5, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Small Circuit Board: stap 5, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 6, afbeelding 1 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 6, afbeelding 2 van 3 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement: stap 6, afbeelding 3 van 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
    Any idea if I can buy a replacement ribbion cable
    Randy Pellerin - Antwoord
  7. HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: stap 7, afbeelding 1 van 2 HP Windows Mixed Reality Controllers TPC-Q044 Joystick Switch Replacement, Joystick Switch: stap 7, afbeelding 2 van 2
    • The joystick controller is soldered directly to the circuit board. You can find instructions for removing soldered components here.
    • The joystick controller is secured by 12 solder connections. Once these have been desoldered, the controller can be removed.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Clement Cheung
643 Reputatie
5 handleidingen geschreven
Cal Poly, Team S18-G5, White Winter 2019 Lid van Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Leden
14 handleidingen geschreven
2 opmerkingen
You can solder replacement Xbox One analog sticks right? I have some stick drift and can’t test this until my university reopens, but when it does I want to try fixing it.
Edit: I have the Dell controllers but they seem identical to the HP ones in this guide.
Vincent - Antwoord
I think this might be the stick: https://www.mouser.com/ProductDetail/Alp...
Alps RKJXV 23 degree 10K ohm multi-directional switches
I haven’t soldered it yet so do not take my word as fact, it just looks right.
Vincent - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,201
