Ga door naar hoofdinhoud
HP Stream 7 Motherboard Replacement
Wat je nodig hebt
    1. HP Stream 7  Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP Stream 7  Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Stream 7  Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Stream 7  Motherboard Replacement: stap 2, afbeelding 2 van 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Stream 7  Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Stream 7  Motherboard Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: stap 4, afbeelding 1 van 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Stream 7  Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Stream 7  Motherboard Replacement: stap 5, afbeelding 2 van 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Stream 7  Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Stream 7  Motherboard Replacement: stap 6, afbeelding 2 van 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin Schnorf
252 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-5, Forte Fall 2016 Lid van Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 2,097
