Ga door naar hoofdinhoud
HP Stream 11-d010nr Webcam Replacement
Wat je nodig hebt
    1. HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: stap 1, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: stap 1, afbeelding 2 van 2
      • Unplug and turn off the HP Stream 11 before disassembling the device.
      • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
      • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Stream 11-d010nr Webcam Replacement, Unscrew the back cover: stap 2, afbeelding 1 van 1
      • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
      • Keep the screws in a safe place for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: stap 3, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: stap 3, afbeelding 2 van 2
      • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
      • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
      • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Stream 11-d010nr Webcam Replacement, Identify the connectors: stap 4, afbeelding 1 van 1
      • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
      • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: stap 5, afbeelding 1 van 3 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: stap 5, afbeelding 2 van 3 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: stap 5, afbeelding 3 van 3
      • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
      • Carefully disconnect the three ribbon cables.
      Vraag FixBot
      Voeg opmerking toe
    6. HP Stream 11-d010nr Webcam Replacement, Lift the keyboard out: stap 6, afbeelding 1 van 1
      • Gently lift the keyboard out of the laptop to fully detach it from the device.
      • While handling, avoid damaging any remaining components.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Stream 11-d010nr Webcam Replacement, Battery: stap 7, afbeelding 1 van 1
      • Remove any tape holding the battery connector in place.
      • Using your fingers, carefully unplug the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Stream 11-d010nr Webcam Replacement: stap 8, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement: stap 8, afbeelding 2 van 2
      • Remove the four 3mm #000 Phillips screws holding the battery in place.
      • Carefully lift the battery out of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Stream 11-d010nr Webcam Replacement, Wifi Chip: stap 9, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement, Wifi Chip: stap 9, afbeelding 2 van 2
      • Unplug the black wire attached to the wireless chip.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Stream 11-d010nr Webcam Replacement: stap 10, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement: stap 10, afbeelding 2 van 2
      • Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
      • Lift the wireless chip up and out.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Stream 11-d010nr Webcam Replacement, Webcam: stap 11, afbeelding 1 van 3 HP Stream 11-d010nr Webcam Replacement, Webcam: stap 11, afbeelding 2 van 3 HP Stream 11-d010nr Webcam Replacement, Webcam: stap 11, afbeelding 3 van 3
      • Flip up the flap and unplug the display cord from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Stream 11-d010nr Webcam Replacement: stap 12, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement: stap 12, afbeelding 2 van 2
      • Using a JIS #1 screwdriver, remove the four 2.2 mm screws holding monitor to body.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Stream 11-d010nr Webcam Replacement: stap 13, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use tweezers to remove the screw covers from the lid.
      • Unscrew the two 2.2 mm #000 Phillips screws.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Stream 11-d010nr Webcam Replacement: stap 14, afbeelding 1 van 1
      • Open the upper lid with the iFixit opening tool.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Stream 11-d010nr Webcam Replacement: stap 15, afbeelding 1 van 2 HP Stream 11-d010nr Webcam Replacement: stap 15, afbeelding 2 van 2
      • Disconnect the webcam cord using tweezers.
      • Remove the webcam using tweezers.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Zachary Heisler
382 Reputatie
3 handleidingen geschreven
Cal Poly, Team S1-G3, White Winter 2019 Lid van Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 725
