Ga door naar hoofdinhoud
HP Stream 11-d010nr Clickpad Replacement
Wat je nodig hebt
  1. HP Stream 11-d010nr Clickpad Replacement, Pry out the inserts: stap 1, afbeelding 1 van 2 HP Stream 11-d010nr Clickpad Replacement, Pry out the inserts: stap 1, afbeelding 2 van 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Stream 11-d010nr Clickpad Replacement, Unscrew the back cover: stap 2, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Stream 11-d010nr Clickpad Replacement, Pry the keyboard casing up: stap 3, afbeelding 1 van 2 HP Stream 11-d010nr Clickpad Replacement, Pry the keyboard casing up: stap 3, afbeelding 2 van 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Stream 11-d010nr Clickpad Replacement, Identify the connectors: stap 4, afbeelding 1 van 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: stap 5, afbeelding 1 van 3 HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: stap 5, afbeelding 2 van 3 HP Stream 11-d010nr Clickpad Replacement, Disconnect the cables: stap 5, afbeelding 3 van 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Stream 11-d010nr Clickpad Replacement, Lift the keyboard out: stap 6, afbeelding 1 van 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Stream 11-d010nr Clickpad Replacement, Clickpad: stap 7, afbeelding 1 van 2 HP Stream 11-d010nr Clickpad Replacement, Clickpad: stap 7, afbeelding 2 van 2
    • Remove the two 2mm #000 Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Stream 11-d010nr Clickpad Replacement: stap 8, afbeelding 1 van 1
    • Release the clickpad by lifting the keyboard up.
    • When installing the new clickpad, make sure the black tabs go into the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Josh Corrigan
353 Reputatie
2 handleidingen geschreven
Cal Poly, Team S1-G3, White Winter 2019 Lid van Cal Poly, Team S1-G3, White Winter 2019
CPSU-WHITE-W19S1G3
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 597
