Ga door naar hoofdinhoud
HP Spectre 13 4003dx x360 Display Assembly Replacement
Wat je nodig hebt
  1. HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 2, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 2, afbeelding 2 van 2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 3, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 4, afbeelding 1 van 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 4, afbeelding 2 van 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 4, afbeelding 3 van 3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 1 van 3 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 2 van 3 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: stap 5, afbeelding 3 van 3
    • Remove the two 2mm Phillips #00 screws from the fan.
    • Disconnect the fan from the motherboard.
  6. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 6, afbeelding 1 van 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 6, afbeelding 2 van 3 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 6, afbeelding 3 van 3
    • Using minimal force, disconnect both WiFi antennae cables.
    • Remove the single Phillips #00 screw that secures the WiFi card.
    • Slide the WiFi card up until it is completely removed.
    • Do not pull up on the wireless module while it is still seated. You may inadvertently damage it.
  7. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 7, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • Remove the four hinge screw with a Phillips #00 screwdriver.
  8. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 8, afbeelding 1 van 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 8, afbeelding 2 van 2
    • Grip the black tape and pull up to unplug.
  9. HP Spectre 13 4003dx x360 Display Assembly Replacement: stap 9, afbeelding 1 van 1
    • Separate the display assembly from the body of the computer.
    • As a result of the orientation of the hinges, you may need to rotate open the laptop to around 270 degrees to clear them.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Ethan Plumer
605 Reputatie
2 handleidingen geschreven
USF Tampa, Team S5-G4, Passmore Spring 2018 Lid van USF Tampa, Team S5-G4, Passmore Spring 2018
USFT-PASSMORE-S18S5G4
3 Leden
8 handleidingen geschreven
2 opmerkingen
You forgot to mention that some people may have to remove the heatsink like I did before the screen will come off.
Wargaming Super Noob - Antwoord
Anyone have any tips on reconnecting the WIFI antennas? I finally gave up and just decided to get a USB dongleā€¦ worked out well otherwise. I did also have to remove the heatsink like Wargaming Super Noob mentioned.
David Bergeron - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 47
Altijd: 9,749
