Ga door naar hoofdinhoud
HP Slate 8 Pro Battery Replacement
Wat je nodig hebt
  1. HP Slate 8 Pro Battery Replacement, Remove Back Panel: stap 1, afbeelding 1 van 2 HP Slate 8 Pro Battery Replacement, Remove Back Panel: stap 1, afbeelding 2 van 2
    • Secure the suction cup to the center of the device’s screen.
    • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Slate 8 Pro Battery Replacement, Remove yellow cables: stap 2, afbeelding 1 van 2 HP Slate 8 Pro Battery Replacement, Remove yellow cables: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use the tweezers to disconnect the battery connector from the circuit board.
    • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Slate 8 Pro Battery Replacement, Remove Screws Around Battery: stap 3, afbeelding 1 van 1
    • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Slate 8 Pro Battery Replacement, Lift Battery out of Device: stap 4, afbeelding 1 van 1
    • Grasp the battery and remove it from the device.
    • Do not attempt to open or tamper with the battery. This could result in injury.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jose Revelo
311 Reputatie
3 handleidingen geschreven
USF Tampa, Team 9-4, Blackwell Fall 2014 Lid van USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Leden
10 handleidingen geschreven
1Gids Commentaar
Nahi hua hai
Md Mozahid - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 3,690
