Ga door naar hoofdinhoud
HP Slate 7 4601 Front Screen Replacement
Wat je nodig hebt
    1. HP Slate 7 4601 Front Screen Replacement, Battery: stap 1, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement, Battery: stap 1, afbeelding 2 van 2
      • Begin your replacement by using a T3 or T4 Torx screwdriver.
      • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Slate 7 4601 Front Screen Replacement: stap 2, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 2, afbeelding 2 van 2
      • With the pointed end of the spudger, remove the thin metal band.
      • It is easiest to remove the metal band through the headphone opening.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Slate 7 4601 Front Screen Replacement: stap 3, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 3, afbeelding 2 van 2
      • Using the flat end of the spudger, pry back the rear plastic cover.
      • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Slate 7 4601 Front Screen Replacement: stap 4, afbeelding 1 van 1
      • Remove the rear cover.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Slate 7 4601 Front Screen Replacement: stap 5, afbeelding 1 van 1
      • Locate and remove the yellow tape covering the red and white speaker wires.
      Vraag FixBot
      Voeg opmerking toe
    6. HP Slate 7 4601 Front Screen Replacement: stap 6, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 6, afbeelding 2 van 2
      • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
      • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
      • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
      Vraag FixBot
      Voeg opmerking toe
    7. HP Slate 7 4601 Front Screen Replacement: stap 7, afbeelding 1 van 1
      • Gently pull back the foil covering the gold charging port ribbon.
      Vraag FixBot
      Voeg opmerking toe
    8. HP Slate 7 4601 Front Screen Replacement: stap 8, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 8, afbeelding 2 van 2
      • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
      • Gently slide the charging port ribbon out from its housing.
      • It may be easier to use the pointed end of the spudger than your fingers.
      Vraag FixBot
      Voeg opmerking toe
    9. HP Slate 7 4601 Front Screen Replacement: stap 9, afbeelding 1 van 1
      • Lift gold charging strip away from the battery.
      Vraag FixBot
      Voeg opmerking toe
    10. HP Slate 7 4601 Front Screen Replacement: stap 10, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 10, afbeelding 2 van 2
      • Push the white battery connector out of its housing using the pointed end of the spudger.
      Vraag FixBot
      Voeg opmerking toe
    11. HP Slate 7 4601 Front Screen Replacement: stap 11, afbeelding 1 van 1
      • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
      • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
      • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    12. HP Slate 7 4601 Front Screen Replacement: stap 12, afbeelding 1 van 1
      • Lift battery out of its place and set aside.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Slate 7 4601 Front Screen Replacement, Charging Port: stap 13, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement, Charging Port: stap 13, afbeelding 2 van 2
      • To free the speaker assembly, you will need a #00 Phillips Head screwdriver.
      • Remove the two 1.75mm x 3mm Phillips Head screws from the speaker assembly.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Slate 7 4601 Front Screen Replacement: stap 14, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 14, afbeelding 2 van 2
      • Pull back the foil overlapping the charging port to reveal another 1.75mm x 3mm Phillips Head screw.
      • Remove the screw with a #00 Phillips Head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Slate 7 4601 Front Screen Replacement: stap 15, afbeelding 1 van 1
      • Lift the charging port and set it aside.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Slate 7 4601 Front Screen Replacement, Speaker: stap 16, afbeelding 1 van 1
      • Lift the two speakers out of the device and set them aside.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Slate 7 4601 Front Screen Replacement, Motherboard: stap 17, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement, Motherboard: stap 17, afbeelding 2 van 2
      • Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
      • When reconnecting the LCD connector ribbon, make sure that it's pushed in all the way. If it isn't, there will be horizontal lines when you power the tablet on.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Slate 7 4601 Front Screen Replacement: stap 18, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 18, afbeelding 2 van 2
      • Likewise, disconnect the square radio chip ribbon by lifting up the black panel with a spudger and sliding the gold strip out.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Slate 7 4601 Front Screen Replacement: stap 19, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 19, afbeelding 2 van 2
      • You will be using a #00 Phillips Head screwdriver to free the motherboard.
      • Remove the six 1.75mm x 3mm Phillips Head screws holding the motherboard to the screen.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Slate 7 4601 Front Screen Replacement: stap 20, afbeelding 1 van 2 HP Slate 7 4601 Front Screen Replacement: stap 20, afbeelding 2 van 2
      • Using your hand, lift up the silver tape from the copper plate.
      • Lift the motherboard out of the device.
      • You may need to wiggle and work the motherboard to get it released from the device
      Vraag FixBot
      Voeg opmerking toe
    1. HP Slate 7 4601 Front Screen Replacement, Front Screen / Volume Buttons: stap 21, afbeelding 1 van 1
      • Remove the metal band surrounding the device by lifting it up out of the placement pins. Begin at one end and work your way around.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Slate 7 4601 Front Screen Replacement: stap 22, afbeelding 1 van 1
      • You now have access to the LCD screen.
      • You can replace the volume rocker by lifting it up and out of the device.
      • The volume rocker should be reinserted so the "up" button is toward the top of the tablet during reassembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
14 andere personen hebben deze handleiding voltooid.
Ryan ONeill
2.130 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-30, Maness Spring 2014 Lid van Cal Poly, Team 13-30, Maness Spring 2014
CPSU-MANESS-S14S13G30
3 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 48
Altijd: 23,881
