Inleiding
Use this guide to replace a faulty or damaged battery in the HP ProBook 640 G5. If your laptop isn't turning on, has issues charging, or is draining power fast, it's most likely that the battery may be damaged or is faulty. This guide will show you step by step how to take off the back cover of your laptop, find where the battery is, and finally how to replace it.
Wat je nodig hebt
Shut down the HP ProBook 640 G5 completely.
Disconnect the power adapter and all connected peripherals.
Press and hold the power button for 5 seconds to discharge remaining electricity.
Flip the laptop over so the bottom is facing up.
Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
Remove two black 6mm screws using a TR7 Torx screwdriver.
Insert a plastic opening tool into the seam and gently pry around the edges.
Lift the bottom cover away from the laptop.
