Inleiding
This guide will walk you through the process of removing the midframe of your HP ProBook 640 G1 to access internal components such as the RAM, hard drive or SSD, CPU and other serviceable hardware.
Before you begin, make sure the laptop is fully powered off and not in sleep mode. Disconnect the charger and any external devices.
Wat je nodig hebt
Remove the eight rubber screw plugs from the bottom and the two rubber screw plugs from the sides of the laptop using a paperclip.
Remove the fourteen 6 mm screws from the bottom of the laptop and the two 6 mm screws from the sides using a T8 Torx screwdriver.
Remove the six 4 mm screws that secure the midframe using a T8 Torx screwdriver.
