Ga door naar hoofdinhoud
HP ProBook 4520s Screen Replacement
Wat je nodig hebt
  1. HP ProBook 4520s Screen Replacement, Battery: stap 1, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
    Vraag FixBot
    Voeg opmerking toe
  2. HP ProBook 4520s Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by holding the latches and sliding the battery away from you.
    Vraag FixBot
    Voeg opmerking toe
  3. HP ProBook 4520s Screen Replacement, Switch Cover: stap 3, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement, Switch Cover: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
    Vraag FixBot
    Voeg opmerking toe
  4. HP ProBook 4520s Screen Replacement: stap 4, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement: stap 4, afbeelding 2 van 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
    Vraag FixBot
    Voeg opmerking toe
  5. HP ProBook 4520s Screen Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
    Vraag FixBot
    Voeg opmerking toe
  6. HP ProBook 4520s Screen Replacement: stap 6, afbeelding 1 van 3 HP ProBook 4520s Screen Replacement: stap 6, afbeelding 2 van 3 HP ProBook 4520s Screen Replacement: stap 6, afbeelding 3 van 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
    Vraag FixBot
    Voeg opmerking toe
  7. HP ProBook 4520s Screen Replacement, Screen: stap 7, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement, Screen: stap 7, afbeelding 2 van 2
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
    Vraag FixBot
    Voeg opmerking toe
  8. HP ProBook 4520s Screen Replacement: stap 8, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement: stap 8, afbeelding 2 van 2
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
    Vraag FixBot
    Voeg opmerking toe
  9. HP ProBook 4520s Screen Replacement: stap 9, afbeelding 1 van 3 HP ProBook 4520s Screen Replacement: stap 9, afbeelding 2 van 3 HP ProBook 4520s Screen Replacement: stap 9, afbeelding 3 van 3
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
    Vraag FixBot
    Voeg opmerking toe
  10. HP ProBook 4520s Screen Replacement: stap 10, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement: stap 10, afbeelding 2 van 2
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
    Vraag FixBot
    Voeg opmerking toe
  11. HP ProBook 4520s Screen Replacement: stap 11, afbeelding 1 van 1
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
    Vraag FixBot
    Voeg opmerking toe
  12. HP ProBook 4520s Screen Replacement: stap 12, afbeelding 1 van 1
    • Gently push the back cover away.
    Vraag FixBot
    Voeg opmerking toe
  13. HP ProBook 4520s Screen Replacement: stap 13, afbeelding 1 van 3 HP ProBook 4520s Screen Replacement: stap 13, afbeelding 2 van 3 HP ProBook 4520s Screen Replacement: stap 13, afbeelding 3 van 3
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
    Vraag FixBot
    Voeg opmerking toe
  14. HP ProBook 4520s Screen Replacement: stap 14, afbeelding 1 van 3 HP ProBook 4520s Screen Replacement: stap 14, afbeelding 2 van 3 HP ProBook 4520s Screen Replacement: stap 14, afbeelding 3 van 3
    • Peel the ribbon cable away from the screen.
    Vraag FixBot
    Voeg opmerking toe
  15. HP ProBook 4520s Screen Replacement: stap 15, afbeelding 1 van 2 HP ProBook 4520s Screen Replacement: stap 15, afbeelding 2 van 2
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Robert Spencer Harrison
1.422 Reputatie
4 handleidingen geschreven
UC Davis, Team 1-3, Oliver Fall 2016 Lid van UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Leden
8 handleidingen geschreven
2Gids Commentaar
I need back cover hp i5 probook 4520s
amir86216 - Antwoord Deel
I need speakers hp probook 4520s i5
Osagie Rmd - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 46
Altijd: 6,997
