Ga door naar hoofdinhoud
HP ProBook 4320t Wi-Fi Card Replacement Guide
Wat je nodig hebt
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: stap 1, afbeelding 1 van 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Battery Removal: stap 1, afbeelding 2 van 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: stap 2, afbeelding 1 van 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Screws: stap 2, afbeelding 2 van 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Flip: stap 3, afbeelding 1 van 1
      • Flip laptop over and open it.
      Vraag FixBot
      Voeg opmerking toe
    4. HP ProBook 4320t Wi-Fi Card Replacement Guide, Push N Lift: stap 4, afbeelding 1 van 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrewing: stap 5, afbeelding 1 van 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: stap 6, afbeelding 1 van 2 HP ProBook 4320t Wi-Fi Card Replacement Guide, Careful Now: stap 6, afbeelding 2 van 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: stap 7, afbeelding 1 van 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Unscrew: stap 8, afbeelding 1 van 1
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide, Slide the Panel Off: stap 9, afbeelding 1 van 1
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide, Lift up Carefully: stap 10, afbeelding 1 van 1
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      Vraag FixBot
      Voeg opmerking toe
    4. HP ProBook 4320t Wi-Fi Card Replacement Guide, Disconnect Wire: stap 11, afbeelding 1 van 1
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Wi-Fi Card Replacement Guide, Wi-Fi Card: stap 12, afbeelding 1 van 1
      • Use black spudger to detach the two antenna cable connectors to the Wi-Fi card.
      • Be careful not to break the cords.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Wi-Fi Card Replacement Guide: stap 13, afbeelding 1 van 1
      • Unscrew the two (2.5 mm Phillips) screws holding the wifi card in.
      • Be careful because upon the last turn of the screw, the Wi-Fi card lifts up slightly.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Wi-Fi Card Replacement Guide: stap 14, afbeelding 1 van 1
      • Pull the Wi-Fi card towards the left to remove.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joshua
134 Reputatie
6 handleidingen geschreven
USF Tampa, Team 9-5, Blackwell Fall 2014 Lid van USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Leden
30 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 902
