Ga door naar hoofdinhoud
HP ProBook 4320t Processor Heat Sink Replacement Guide
Wat je nodig hebt
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: stap 1, afbeelding 1 van 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Battery Removal: stap 1, afbeelding 2 van 2
      • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: stap 2, afbeelding 1 van 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Screws: stap 2, afbeelding 2 van 2
      • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Flip: stap 3, afbeelding 1 van 1
      • Flip laptop over and open it.
      Vraag FixBot
      Voeg opmerking toe
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Push N Lift: stap 4, afbeelding 1 van 1
      • Slightly push up while lifting up on the power button panel to release the panel.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrewing: stap 5, afbeelding 1 van 1
      • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: stap 6, afbeelding 1 van 2 HP ProBook 4320t Processor Heat Sink Replacement Guide, Careful Now: stap 6, afbeelding 2 van 2
      • Carefully (holding both sides of the keyboard), push up and lift slightly.
      • Keyboard is still connected via a ribbon cable.
      • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: stap 7, afbeelding 1 van 1
      • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Unscrew: stap 8, afbeelding 1 van 1
      • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide, Slide the Panel Off: stap 9, afbeelding 1 van 1
      • Carefully slide the bottom panel to the right.
      • Keyboard is connected via a wire to the back of the panel.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide, Lift up Carefully: stap 10, afbeelding 1 van 1
      • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
      • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
      Vraag FixBot
      Voeg opmerking toe
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide, Disconnect Wire: stap 11, afbeelding 1 van 1
      • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Computer Fan: stap 12, afbeelding 1 van 1
      • Locate silver holding panel on the left side of the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: stap 13, afbeelding 1 van 1
      • Unscrew the five silver (2.5 mm Phillips) screws that are holding the panel in.
      • Unscrew the two black (3.0 mm Phillips) screws that are holding the panel in.
      Vraag FixBot
      Voeg opmerking toe
    3. HP ProBook 4320t Processor Heat Sink Replacement Guide: stap 14, afbeelding 1 van 1
      • Remove holding panel and put aside.
      Vraag FixBot
      Voeg opmerking toe
    4. HP ProBook 4320t Processor Heat Sink Replacement Guide: stap 15, afbeelding 1 van 1
      • Disconnect the red, black, and blue ribbon cable connector using the black spudger.
      Vraag FixBot
      Voeg opmerking toe
    5. HP ProBook 4320t Processor Heat Sink Replacement Guide: stap 16, afbeelding 1 van 1
      • Unscrew the one (2.0 mm Phillips) screw holding in the fan.
      Vraag FixBot
      Voeg opmerking toe
    6. HP ProBook 4320t Processor Heat Sink Replacement Guide: stap 17, afbeelding 1 van 1
      • Lift fan up carefully and replace.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 4320t Processor Heat Sink Replacement Guide, Processor Heat Sink: stap 18, afbeelding 1 van 1
      • Unscrew the four (2.5 mm Phillips) screws holding the processor heat sink in (located near the center of the laptop)
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 4320t Processor Heat Sink Replacement Guide: stap 19, afbeelding 1 van 1
      • Lift slightly on the main component of the heat sink and slowly pull in towards the center (to your right) to free the heat sink.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eric Markham
227 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-5, Blackwell Fall 2014 Lid van USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 1,426
