Ga door naar hoofdinhoud
HP Pavilion zv5000 Screen Replacement
Wat je nodig hebt
  1. HP Pavilion zv5000 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Pavilion zv5000 Screen Replacement: stap 2, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 2, afbeelding 2 van 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Pavilion zv5000 Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 3, afbeelding 2 van 2
    • Using two fingers, pry the rest of the battery out of the socket.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Pavilion zv5000 Screen Replacement, Keyboard: stap 4, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Pavilion zv5000 Screen Replacement: stap 5, afbeelding 1 van 1
    • Flip laptop back over and open as far as it can go.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Pavilion zv5000 Screen Replacement: stap 6, afbeelding 1 van 1
    • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
    • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Pavilion zv5000 Screen Replacement: stap 7, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 7, afbeelding 2 van 2
    • Use hands to completely lift off the strip cover and remove.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Pavilion zv5000 Screen Replacement: stap 8, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Pavilion zv5000 Screen Replacement: stap 9, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 9, afbeelding 2 van 2
    • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
    • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Pavilion zv5000 Screen Replacement: stap 10, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 10, afbeelding 2 van 2
    • Gently slide out the connecting cable from the laptop to the keyboard.
    • Do not aggressively pull at the connecting cable.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Pavilion zv5000 Screen Replacement: stap 11, afbeelding 1 van 1
    • Completely remove the keyboard from the rest of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  12. HP Pavilion zv5000 Screen Replacement, Screen: stap 12, afbeelding 1 van 1
    • Flip the Pavilion back over on its backside.
    Vraag FixBot
    Voeg opmerking toe
  13. HP Pavilion zv5000 Screen Replacement: stap 13, afbeelding 1 van 3 HP Pavilion zv5000 Screen Replacement: stap 13, afbeelding 2 van 3 HP Pavilion zv5000 Screen Replacement: stap 13, afbeelding 3 van 3
    • Using the same Phillips #0 screwdriver, unscrew the six Phillips PM 2.5X6.0mm screws.
    • Also remove the four Phillips PM 2.5X13.0mm screws to remove the thermal plate with the same screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  14. HP Pavilion zv5000 Screen Replacement: stap 14, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 14, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Flip the laptop back over and open the lid all the way.
    • Using the flat edge of the plastic spudger, pry straight up to remove the Mini PCI Connector Cables from the board.
    • Tweezers can also be used to gently squeeze and pull up on the Mini PCI Cable Connectors to remove from the board.
    • When reinstalling, place the Mini PCI Connector Cables back in place and gently press straight down until they snap into place.
    Vraag FixBot
    Voeg opmerking toe
  15. HP Pavilion zv5000 Screen Replacement: stap 15, afbeelding 1 van 3 HP Pavilion zv5000 Screen Replacement: stap 15, afbeelding 2 van 3 HP Pavilion zv5000 Screen Replacement: stap 15, afbeelding 3 van 3
    • Using the tweezers, gently squeeze and pull backwards on the display cable until it is disconnected.
    • To reinsert, simply align the display cable to its proper spot and gently push into place.
    Vraag FixBot
    Voeg opmerking toe
  16. HP Pavilion zv5000 Screen Replacement: stap 16, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 16, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver again to remove the four Phillips 2.5X13.0mm screws that hold the clips for the screen into place.
    Vraag FixBot
    Voeg opmerking toe
  17. HP Pavilion zv5000 Screen Replacement: stap 17, afbeelding 1 van 2 HP Pavilion zv5000 Screen Replacement: stap 17, afbeelding 2 van 2
    • Turn the laptop around until the top cover is facing you. Keep the laptop in an open position.
    • Unscrew the four Phillips PM 2.5X6.0mm screws using the Phillips #0 that hold the clips of the screen on to the base.
    Vraag FixBot
    Voeg opmerking toe
  18. HP Pavilion zv5000 Screen Replacement: stap 18, afbeelding 1 van 1
    • Firmly grasp the top of the screen with your hands and pull towards you and upwards to remove the screen from the base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Eliza Marks
676 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-6, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 1,603
