Ga door naar hoofdinhoud
HP Pavilion zv5000 Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion zv5000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Pavilion zv5000 Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Pavilion zv5000 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Pavilion zv5000 Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Pavilion zv5000 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Using two fingers, pry the rest of the battery out of the socket.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Pavilion zv5000 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 HP Pavilion zv5000 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Pavilion zv5000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Flip laptop back over and open as far as it can go.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Pavilion zv5000 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
    • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Pavilion zv5000 Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Pavilion zv5000 Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Use hands to completely lift off the strip cover and remove.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Pavilion zv5000 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Pavilion zv5000 Keyboard Replacement: stap 9, afbeelding 1 van 2 HP Pavilion zv5000 Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
    • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Pavilion zv5000 Keyboard Replacement: stap 10, afbeelding 1 van 2 HP Pavilion zv5000 Keyboard Replacement: stap 10, afbeelding 2 van 2
    • Gently slide out the connecting cable from the laptop to the keyboard.
    • Do not aggressively pull at the connecting cable.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Pavilion zv5000 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Completely remove the keyboard from the rest of the laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Eliza Marks
676 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 4-6, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 29
Altijd: 1,278
