Ga door naar hoofdinhoud
HP Pavilion x360 11-p110nr Battery Replacement
Wat je nodig hebt
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion x360 11-p110nr Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion x360 11-p110nr Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
Conclusie
AljeannaJohnson
202 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 625
