Ga door naar hoofdinhoud
HP Pavilion tx2500 Screen Rotator Replacement
Wat je nodig hebt
  1. HP Pavilion tx2500 Screen Rotator Replacement, Screen Rotator: stap 1, afbeelding 1 van 1
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Pavilion tx2500 Screen Rotator Replacement: stap 2, afbeelding 1 van 2 HP Pavilion tx2500 Screen Rotator Replacement: stap 2, afbeelding 2 van 2
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Pavilion tx2500 Screen Rotator Replacement: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Pavilion tx2500 Screen Rotator Replacement: stap 4, afbeelding 1 van 1
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Pavilion tx2500 Screen Rotator Replacement: stap 5, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Pavilion tx2500 Screen Rotator Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to disconnect the wires in the upper corners.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Pavilion tx2500 Screen Rotator Replacement: stap 7, afbeelding 1 van 1
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Pavilion tx2500 Screen Rotator Replacement: stap 8, afbeelding 1 van 1
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Pavilion tx2500 Screen Rotator Replacement: stap 9, afbeelding 1 van 2 HP Pavilion tx2500 Screen Rotator Replacement: stap 9, afbeelding 2 van 2
    • Rotate the screen 90 degrees and remove the base under the screen.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Pavilion tx2500 Screen Rotator Replacement: stap 10, afbeelding 1 van 1
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Pavilion tx2500 Screen Rotator Replacement: stap 11, afbeelding 1 van 2 HP Pavilion tx2500 Screen Rotator Replacement: stap 11, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
    Vraag FixBot
    Voeg opmerking toe
  12. HP Pavilion tx2500 Screen Rotator Replacement: stap 12, afbeelding 1 van 1
    • Gently lift up and remove the screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sarah Naiser
336 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 919
