Ga door naar hoofdinhoud
HP Pavilion dv4000 Keyboard Replacement
Wat je nodig hebt
    1. HP Pavilion dv4000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
      • Turn the laptop upside down with the battery compartment facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Pavilion dv4000 Keyboard Replacement: stap 2, afbeelding 1 van 1
      • Slide the battery release latch to the right and hold in place.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Pavilion dv4000 Keyboard Replacement: stap 3, afbeelding 1 van 1
      • Lift the front edge of the battery up and remove it from the compartment.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Pavilion dv4000 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
      • Have your device open in front of you for easy access to the keyboard.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Pavilion dv4000 Keyboard Replacement: stap 5, afbeelding 1 van 1
      • Using a metal spudger, pry up on the plastic piece above the keyboard containing the power button.
      • Be careful not to damage any components with the tool while prying.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Pavilion dv4000 Keyboard Replacement: stap 6, afbeelding 1 van 1
      • Lift the plastic piece up.
      • When lifting this piece, be careful not to damage the ribbon strip connected to it.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Pavilion dv4000 Keyboard Replacement: stap 7, afbeelding 1 van 3 HP Pavilion dv4000 Keyboard Replacement: stap 7, afbeelding 2 van 3 HP Pavilion dv4000 Keyboard Replacement: stap 7, afbeelding 3 van 3
      • Place the plastic piece on the keyboard so the ribbon strip is easily accessible.
      • Carefully disconnect the ribbon strip from the keyboard by pressing on the tabs at the edges.
      • Remove plastic piece and set aside.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Pavilion dv4000 Keyboard Replacement: stap 8, afbeelding 1 van 1
      • Locate the four 2x2 mm screws that hold the keyboard in place.
      Vraag FixBot
      Voeg opmerking toe
    6. HP Pavilion dv4000 Keyboard Replacement: stap 9, afbeelding 1 van 1
      • Unscrew the four 2x2 mm screws with a #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. HP Pavilion dv4000 Keyboard Replacement: stap 10, afbeelding 1 van 2 HP Pavilion dv4000 Keyboard Replacement: stap 10, afbeelding 2 van 2
      • Lift the keyboard up.
      • When lifting the keyboard, be sure not to damage the ribbon strip that is connected to it.
      Vraag FixBot
      Voeg opmerking toe
    8. HP Pavilion dv4000 Keyboard Replacement: stap 11, afbeelding 1 van 1
      • Locate where the ribbon strip is connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    9. HP Pavilion dv4000 Keyboard Replacement: stap 12, afbeelding 1 van 2 HP Pavilion dv4000 Keyboard Replacement: stap 12, afbeelding 2 van 2
      • Pry at the edges of the plastic clip holding the ribbon cable to the motherboard.
      • Be careful during this step as these clips are very easy to break.
      Vraag FixBot
      Voeg opmerking toe
    10. HP Pavilion dv4000 Keyboard Replacement: stap 13, afbeelding 1 van 3 HP Pavilion dv4000 Keyboard Replacement: stap 13, afbeelding 2 van 3 HP Pavilion dv4000 Keyboard Replacement: stap 13, afbeelding 3 van 3
      • Remove the keyboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick LaMarche
373 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-2, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
3 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 23
Altijd: 1,274
