Ga door naar hoofdinhoud
HP Pavilion G6 Screen Replacement
Wat je nodig hebt
  1. HP Pavilion G6  Screen Replacement, Remove the battery: stap 1, afbeelding 1 van 3 HP Pavilion G6  Screen Replacement, Remove the battery: stap 1, afbeelding 2 van 3 HP Pavilion G6  Screen Replacement, Remove the battery: stap 1, afbeelding 3 van 3
    • Close the laptop and flip it over.
    • Slide the release pin to pop the battery.
    • Remove the battery completely.
  2. HP Pavilion G6  Screen Replacement, Remove the screw covers: stap 2, afbeelding 1 van 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: stap 2, afbeelding 2 van 3 HP Pavilion G6  Screen Replacement, Remove the screw covers: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Open the laptop and locate the screw covers.
    • Remove the screw covers at the bottom of the screen with tweezers.
    • Keep them somewhere safe as you will need to stick them back after the repair.
  3. HP Pavilion G6  Screen Replacement, Remove the plastic frame: stap 3, afbeelding 1 van 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: stap 3, afbeelding 2 van 3 HP Pavilion G6  Screen Replacement, Remove the plastic frame: stap 3, afbeelding 3 van 3
    • Unscrew the exposed 2 x Philips screws and set them aside.
    • Starting from the top, pry up the plastic frame with your fingernails or a pry bar.
    • If you are using a pry bar, it can scratch the screen. Apply gentle pressure until the plastic frame pop out all around the frame. Don't force it!
    • Finally, remove the frame.
  4. HP Pavilion G6  Screen Replacement, Release the screen from the frame: stap 4, afbeelding 1 van 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: stap 4, afbeelding 2 van 3 HP Pavilion G6  Screen Replacement, Release the screen from the frame: stap 4, afbeelding 3 van 3
    • Remove the black Philips screw from the top on each side.
    • Remove the bottom screw from the hinge to make an easier access to the screws on the side of the screen.
    • Now that the frame is loose, you can remove the 4 x Philips screws holding the screen in the frame.
  5. HP Pavilion G6  Screen Replacement, Disconnect the screen connector: stap 5, afbeelding 1 van 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: stap 5, afbeelding 2 van 3 HP Pavilion G6  Screen Replacement, Disconnect the screen connector: stap 5, afbeelding 3 van 3
    • Turn the laptop back up and carefully tilt the screen out from the frame and rest it on the keyboard.
    • Don't try to fully remove it yet as it is still attached to the motherboard by the screen cable!
    • Gently lift up the adhesive and disconnect the screen connector. That is the screen released and ready for a change for a new one.
  6. HP Pavilion G6  Screen Replacement, Check the model number before ordering: stap 6, afbeelding 1 van 2 HP Pavilion G6  Screen Replacement, Check the model number before ordering: stap 6, afbeelding 2 van 2
    • Before ordering a new screen make sure that you order the correct model number that is compatible with your old screen.
    • Check the cable connector to make sure you order the correct screen with the correct number of pins.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
honakrisi
3.730 Reputatie
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,504
