Ga door naar hoofdinhoud
HP Pavilion DV3 RAM Replacement
Wat je nodig hebt
  1. HP Pavilion DV3 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
    Vraag FixBot
    Voeg opmerking toe
  2. HP Pavilion DV3 RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV3 RAM Replacement: stap 2, afbeelding 2 van 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Pavilion DV3 RAM Replacement, RAM: stap 3, afbeelding 1 van 3 HP Pavilion DV3 RAM Replacement, RAM: stap 3, afbeelding 2 van 3 HP Pavilion DV3 RAM Replacement, RAM: stap 3, afbeelding 3 van 3
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
    Vraag FixBot
    Voeg opmerking toe
  4. HP Pavilion DV3 RAM Replacement: stap 4, afbeelding 1 van 3 HP Pavilion DV3 RAM Replacement: stap 4, afbeelding 2 van 3 HP Pavilion DV3 RAM Replacement: stap 4, afbeelding 3 van 3
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Pavilion DV3 RAM Replacement: stap 5, afbeelding 1 van 2 HP Pavilion DV3 RAM Replacement: stap 5, afbeelding 2 van 2
    • Using one hand, pull the RAM up and to the left to remove it.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Pavilion DV3 RAM Replacement: stap 6, afbeelding 1 van 1
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Brandon Baldovin
548 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-10, Forte Fall 2013 Lid van Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 2,333
