Ga door naar hoofdinhoud
HP Pavilion 15-cd040wm Battery Replacement
Wat je nodig hebt
  1. HP Pavilion 15-cd040wm Battery Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: stap 1, afbeelding 1 van 2 HP Pavilion 15-cd040wm Battery Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: stap 1, afbeelding 2 van 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-cd040wm Battery Replacement: stap 2, afbeelding 2 van 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Battery Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 15-cd040wm Battery Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 15-cd040wm Battery Replacement: stap 3, afbeelding 3 van 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Battery Replacement, Battery: stap 4, afbeelding 1 van 2 HP Pavilion 15-cd040wm Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Battery Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 15-cd040wm Battery Replacement: stap 5, afbeelding 2 van 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joe Krawczyk
397 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G1, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G1
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 2,091
