Inleiding
Use this guide to replace the heat sink in a HP Pavilion 15-cc561st (product number 1KU29UA).
The heat sink is an important component that keeps the processor cool. It transfers heat from the processor through heat pipes to a fin-stack which transfers heat to the ambient air. Thermal paste helps maximize heat transfer between the processor and heat sink, so it is important to reapply thermal paste before reinstalling the heat sink.
Shut down the laptop, disconnect all external devices, and unplug the AC adapter before beginning. Take the appropriate precautions if your battery is swollen.
You will need replacement thermal paste in order to complete this repair.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95
Use a Phillips #0 screwdriver to remove five screws from the bottom cover:
Two 5.6 mm screws
Three 5.8 mm screws
Use a Phillips #0 screwdriver to remove the five 5.7 mm screws that secure the battery.
Use a Phillips #0 screwdriver to remove the four 3.0 mm screws that secure the heat sink.
