Ga door naar hoofdinhoud
HP Pavilion 14-cf0014dx Touchpad Button Board Replacement
Wat je nodig hebt
  1. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement, Daughterboard: stap 5, afbeelding 1 van 1
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 6, afbeelding 2 van 2
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 7, afbeelding 1 van 1
    • Remove the daughterboard with a pair of tweezers.
  8. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement, Motherboard: stap 8, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement, Motherboard: stap 8, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the single screw securing the SSD to the motherboard.
  9. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 9, afbeelding 1 van 3 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 9, afbeelding 2 van 3 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 9, afbeelding 3 van 3
    • Remove the two 4.2 mm screws with a Phillips #0 screwdriver.
    • Use a spudger to disconnect the fan connector from the motherboard.
    • Remove the fan from the laptop.
  10. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 10, afbeelding 2 van 2
  11. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 11, afbeelding 1 van 1
    • Remove the sliding cable connector with a pair of tweezers.
    • Pull from the white plastic tab and not the cables to avoid ripping them.
  12. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 12, afbeelding 1 van 3 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 12, afbeelding 2 van 3 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 12, afbeelding 3 van 3
    • Remove the 4.2 mm screw with your Phillips #0 screwdriver securing the Wi-Fi card.
    • Use tweezers to detach the coaxial cables from the Wi-Fi card.
    • Hold the tweezers closer to the metal pin to avoid ripping the cable and damaging the connector when removing the clip.
  13. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 13, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the 2.5 mm screws from the motherboard.
  14. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 14, afbeelding 1 van 3 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 14, afbeelding 2 van 3 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 14, afbeelding 3 van 3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • Do not separate the metal clamps (holding the chip) too much to avoid bending them.
    • The RAM stick will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
  15. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 15, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 15, afbeelding 2 van 2
    • Unlock the ZIF connectors with a pair of tweezers.
    • Remove the ribbon cables by the blue tab.
  16. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 16, afbeelding 1 van 1
    • Remove the motherboard from the device.
  17. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement, Touchpad Button Board: stap 17, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the two 2.7 mm screws that secure the touchpad button board.
    • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connectors securing the two ribbon cables connected to the button board.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket by the tab.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  18. HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: stap 18, afbeelding 1 van 1
    • Remove the touchpad button board from the laptop.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ben
85 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 77
