Ga door naar hoofdinhoud
HP Pavilion 14-cf0014dx Display Assembly Replacement
Wat je nodig hebt
  1. HP Pavilion 14-cf0014dx Display Assembly Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Display Assembly Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Display Assembly Replacement, Display Assembly: stap 5, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the 6.8 mm screws securing the hinges.
  6. HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to detach the coaxial cables from the Wi-Fi card.
    • Hold the tweezers closer to the metal pin to avoid ripping the cable and damaging the connector when removing the clip.
  7. HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • First, gently push the tip of a spudger under the metal buckle of the display cable connector to unclip it, then swing it over the socket.
    • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
    • To reconnect:
    • Grip the cable and buckle together and insert the connector fully into its socket.
    • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
    • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
  8. HP Pavilion 14-cf0014dx Display Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove the display assembly from the laptop chassis with your hands.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Angel S
205 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 94
