Ga door naar hoofdinhoud
HP Pavilion 14-cf0014dx Daughterboard Replacement
Wat je nodig hebt
  1. HP Pavilion 14-cf0014dx Daughterboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Daughterboard Replacement: stap 2, afbeelding 1 van 1
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Daughterboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Daughterboard Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and out and remove it from the device.
  5. HP Pavilion 14-cf0014dx Daughterboard Replacement, Daughterboard: stap 5, afbeelding 1 van 1
    • Remove the two 6.7 mm screws with a Phillips #0 screwdriver.
  6. HP Pavilion 14-cf0014dx Daughterboard Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 14-cf0014dx Daughterboard Replacement: stap 6, afbeelding 2 van 2
    • Unlock the ZIF connector with the tip of the spudger.
    • Remove the ribbon cable.
  7. HP Pavilion 14-cf0014dx Daughterboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the daughterboard with a pair of tweezers.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Angel S
205 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 81
