Inleiding
This guide will help you replace your power adapter inside the printer.
Wat je nodig hebt
Turn off the printer and remove the power cable.
Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
