Ga door naar hoofdinhoud
HP Notebook 15-ba018ds Fan Replacement
Wat je nodig hebt
  1. HP Notebook 15-ba018ds Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before beginning, make sure the laptop is completely turned off by pressing the off button and waiting for the screen to turn black.
    • Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Notebook 15-ba018ds Fan Replacement: stap 2, afbeelding 1 van 3 HP Notebook 15-ba018ds Fan Replacement: stap 2, afbeelding 2 van 3 HP Notebook 15-ba018ds Fan Replacement: stap 2, afbeelding 3 van 3
    • Place your thumbs on the slide locks that are next to the hinges and simultaneously push them toward each other to unlock the battery.
    • While still holding onto the slide locks, push the battery away from the laptop with your index fingers.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Notebook 15-ba018ds Fan Replacement, Fan: stap 3, afbeelding 1 van 2 HP Notebook 15-ba018ds Fan Replacement, Fan: stap 3, afbeelding 2 van 2
    • Unscrew the 8 screws on the back cover.
    • There are also two screws in the battery area that need to be removed.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Notebook 15-ba018ds Fan Replacement: stap 4, afbeelding 1 van 1
    • Use an opening tool to help remove the back cover.
    • If you look at the side of the laptop, you can see where it can be separated into two parts.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Notebook 15-ba018ds Fan Replacement: stap 5, afbeelding 1 van 2 HP Notebook 15-ba018ds Fan Replacement: stap 5, afbeelding 2 van 2
    • Remove the three Phillips head screws attached to the fan.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Notebook 15-ba018ds Fan Replacement: stap 6, afbeelding 1 van 2 HP Notebook 15-ba018ds Fan Replacement: stap 6, afbeelding 2 van 2
    • Remove old fan and replace with a new fan.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 1,578
