Ga door naar hoofdinhoud
HP Mini 210-2070NR Keyboard Replacement
Wat je nodig hebt
    1. HP Mini 210-2070NR Keyboard Replacement, Battery and Service Access Cover: stap 1, afbeelding 1 van 1
      • Before beginning, make sure that your computer is turned off and all external power cords are disconnected.
      • Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Mini 210-2070NR Keyboard Replacement: stap 2, afbeelding 1 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 2, afbeelding 2 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 2, afbeelding 3 van 3
      • The battery locking latch is on the bottom right corner; slide it inward to unlock the battery.
      • Slide the battery release latch inwards.
      • Pull the battery towards you to remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Mini 210-2070NR Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 3, afbeelding 3 van 3
      • Slide the service access cover release lever to the right.
      • While holding the lever to the right, lift up the laptop's bottom cover gently and remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Mini 210-2070NR Keyboard Replacement: stap 4, afbeelding 1 van 1
      • Orient the computer as shown in the picture.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Mini 210-2070NR Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 2 HP Mini 210-2070NR Keyboard Replacement, Keyboard: stap 5, afbeelding 2 van 2
      • Using a 00 Phillips screwdriver, unscrew and remove the three 2.0 X 5.0 screws that connect the keyboard to the computer.
      • Each of the screws are labeled with small keyboards next to them.
      • Flip the computer over so that the front is facing you.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Mini 210-2070NR Keyboard Replacement: stap 6, afbeelding 1 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 6, afbeelding 2 van 3 HP Mini 210-2070NR Keyboard Replacement: stap 6, afbeelding 3 van 3
      • Open the computer screen as far as possible. It should be able to lay flat on whatever surface you are working on.
      • Pry along the rear edge of the keyboard away from the PC with the plastic opening tool.
      • Once enough of an opening has been established, gently grasp the edge and pull the keyboard towards you.
      • There is a cable connecting the keyboard to the laptop, so do not attempt to fully remove the keyboard yet or you will damage your device.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Mini 210-2070NR Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Mini 210-2070NR Keyboard Replacement: stap 7, afbeelding 2 van 2
      • Use your fingernail to flip up the black retaining flap attached to the keyboard ZIF connector.
      • Pull the keyboard cable out of its socket to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Mini 210-2070NR Keyboard Replacement: stap 8, afbeelding 1 van 1
      • Remove the keyboard by lifting it away from the computer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Sean Kuster
91 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-23, Amido Fall 2012 Lid van Cal Poly, Team 3-23, Amido Fall 2012
CPSU-AMIDO-F12S3G23
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 25
Altijd: 2,037
