Ga door naar hoofdinhoud
HP Mini 210 RAM Replacement
Wat je nodig hebt
  1. HP Mini 210 RAM Replacement, Battery: stap 1, afbeelding 1 van 2 HP Mini 210 RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Mini 210 RAM Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out from the netbook.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Mini 210 RAM Replacement, Disassembling HP Mini 210 Back Case: stap 3, afbeelding 1 van 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Mini 210 RAM Replacement: stap 4, afbeelding 1 van 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Mini 210 RAM Replacement: stap 5, afbeelding 1 van 1
    • Pull the back case off from the front edge.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Mini 210 RAM Replacement, RAM: stap 6, afbeelding 1 van 1
    • Push out the two plastic prongs on either side of the RAM.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Mini 210 RAM Replacement: stap 7, afbeelding 1 van 1
    • The RAM should pop up allowing for easy removal from its compartment.
    • Pull out the RAM.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Heather Freed
723 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-17, Amido Fall 2012 Lid van Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Leden
1Gids Commentaar
Thanks. The back case is a bit tricky to unclip; also took a bit of work to reassemble the case back on.
Max99 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 42
Altijd: 8,307
