Ga door naar hoofdinhoud
HP Mini 210 CMOS Battery Replacement
Wat je nodig hebt
  1. HP Mini 210 CMOS Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Mini 210 CMOS Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off and unplug the netbook before replacing the battery.
    • Hold the netbook top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
    • The left tab unlocks completely, but you will need to hold the right tab towards the lock symbol as you remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Mini 210 CMOS Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery out from the netbook.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Mini 210 CMOS Battery Replacement, Disassembling HP Mini 210 Back Case: stap 3, afbeelding 1 van 1
    • Turn the netbook to view its edge.
    • Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Mini 210 CMOS Battery Replacement: stap 4, afbeelding 1 van 1
    • If the back case does not separate from the netbook easily, use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Mini 210 CMOS Battery Replacement: stap 5, afbeelding 1 van 1
    • Pull the back case off from the front edge.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Mini 210 CMOS Battery Replacement, CMOS Battery: stap 6, afbeelding 1 van 1
    • Cut one side of the black adhesive ribbon on top of the CMOS battery with a utility blade.
    • Be careful not to scratch or damage the battery or netbook, and be sure to keep your fingers out of the way!
    Vraag FixBot
    Voeg opmerking toe
  7. HP Mini 210 CMOS Battery Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Slowly peel back the black adhesive ribbon with tweezers.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Mini 210 CMOS Battery Replacement: stap 8, afbeelding 1 van 1
    • Pry the CMOS battery out with a plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Mini 210 CMOS Battery Replacement: stap 9, afbeelding 1 van 1
    • Pop the CMOS battery out.
    • When reinstalling, insert the battery back into the slot with the positive terminal facing up.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
8 andere personen hebben deze handleiding voltooid.
Heather Freed
723 Reputatie
8 handleidingen geschreven
Cal Poly, Team 9-17, Amido Fall 2012 Lid van Cal Poly, Team 9-17, Amido Fall 2012
CPSU-AMIDO-F12S9G17
3 Leden
2Gids Commentaar
after need CMOS reset. Screen is black. Is there an easy way on my HP Mini 210?
Carl Louviere - Antwoord Deel
Very good tut. Now my HP Mini 210 can get the right time xD
Byte Core - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 81
Altijd: 17,045
