Ga door naar hoofdinhoud
HP G62-234DX RAM Replacement Replacement
Wat je nodig hebt
  1. HP G62-234DX RAM Replacement Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
    Vraag FixBot
    Voeg opmerking toe
  2. HP G62-234DX RAM Replacement Replacement: stap 2, afbeelding 1 van 1
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
    Vraag FixBot
    Voeg opmerking toe
  3. HP G62-234DX RAM Replacement Replacement, RAM: stap 3, afbeelding 1 van 3 HP G62-234DX RAM Replacement Replacement, RAM: stap 3, afbeelding 2 van 3 HP G62-234DX RAM Replacement Replacement, RAM: stap 3, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove three screws from the back panel.
    • Carefully pull the panel off of the back of the laptop to reveal the RAM sticks.
    Vraag FixBot
    Voeg opmerking toe
  4. HP G62-234DX RAM Replacement Replacement: stap 4, afbeelding 1 van 3 HP G62-234DX RAM Replacement Replacement: stap 4, afbeelding 2 van 3 HP G62-234DX RAM Replacement Replacement: stap 4, afbeelding 3 van 3
    • Two clips secure the RAM stick in place, one on each side. Using your fingers, spread the clips away from the RAM stick.
    • When released, the RAM stick will pop up at a slight angle.
    • Lift the RAM stick to an angle of about 30 degrees and slide it out.
    • When handling the RAM stick, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM stick, slide it in place at about the same angle until it's snug, and then swing it downward until the two clips snap into place.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Cameron Popillo
337 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-1, Ramos Spring 2023 Lid van UMass Dartmouth, Team 5-1, Ramos Spring 2023
UMASSD-RAMOS-S23S5G1
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 445
