Ga door naar hoofdinhoud
HP G62-223CL Wireless Card Replacement
Wat je nodig hebt
    1. HP G62-223CL Wireless Card Replacement, Battery Removal: stap 1, afbeelding 1 van 2 HP G62-223CL Wireless Card Replacement, Battery Removal: stap 1, afbeelding 2 van 2
      • Removing the battery while the laptop is still on may corrupt your files.
      • Turn the device over to expose the bottom of the device.
      • Slide the battery release all the way to the left.
      • There will be a click and the battery will be released from its compartment.
      Vraag FixBot
      Voeg opmerking toe
    2. HP G62-223CL Wireless Card Replacement: stap 2, afbeelding 1 van 1
      • Carefully remove the battery from its compartment.
      Vraag FixBot
      Voeg opmerking toe
    1. HP G62-223CL Wireless Card Replacement, Wireless Card: stap 3, afbeelding 1 van 2 HP G62-223CL Wireless Card Replacement, Wireless Card: stap 3, afbeelding 2 van 2
      • Locate three Phillips head retaining screws which secure the compartment.
      • Use a Phillips #0 screwdriver to loosen the retaining screws.
      • Remove the panel covering the compartment.
      • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
      Vraag FixBot
      Voeg opmerking toe
    2. HP G62-223CL Wireless Card Replacement: stap 4, afbeelding 1 van 3 HP G62-223CL Wireless Card Replacement: stap 4, afbeelding 2 van 3 HP G62-223CL Wireless Card Replacement: stap 4, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Use tweezers to disconnect the gray cable and the black cable from the wireless card.
      Vraag FixBot
      Voeg opmerking toe
    3. HP G62-223CL Wireless Card Replacement: stap 5, afbeelding 1 van 1
      • Use a Phillips #0 screwdriver to remove the single 4mm screw from the corner of the wireless card.
      Vraag FixBot
      Voeg opmerking toe
    4. HP G62-223CL Wireless Card Replacement: stap 6, afbeelding 1 van 1
      • Carefully lift and pull wireless card. It is removed!
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Garret Layton
687 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-4, Sullivan Winter 2015 Lid van USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Leden
30 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 1,451
