Ga door naar hoofdinhoud
HP G62-223CL RAM Replacement
Wat je nodig hebt
  1. HP G62-223CL RAM Replacement, Battery Removal: stap 1, afbeelding 1 van 2 HP G62-223CL RAM Replacement, Battery Removal: stap 1, afbeelding 2 van 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
    Vraag FixBot
    Voeg opmerking toe
  2. HP G62-223CL RAM Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the battery from its compartment.
    Vraag FixBot
    Voeg opmerking toe
  3. HP G62-223CL RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Locate three Phillips head retaining screws which secure RAM compartment.
    • Use a Phillips #0 screwdriver to loosen the screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    Vraag FixBot
    Voeg opmerking toe
  4. HP G62-223CL RAM Replacement: stap 4, afbeelding 1 van 2 HP G62-223CL RAM Replacement: stap 4, afbeelding 2 van 2
    • Use the tip of a screw driver to press the release clips away from the RAM module.
    • Once the second clip is released, the module will automatically pop up.
    Vraag FixBot
    Voeg opmerking toe
  5. HP G62-223CL RAM Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove module from slot.
    • Be careful not to damage modules when removing them from their slots.
    Vraag FixBot
    Voeg opmerking toe
  6. HP G62-223CL RAM Replacement: stap 6, afbeelding 1 van 2 HP G62-223CL RAM Replacement: stap 6, afbeelding 2 van 2
    • Repeat steps 4 and 5 for additional RAM modules.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Garret Layton
687 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-4, Sullivan Winter 2015 Lid van USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 942
