Ga door naar hoofdinhoud
HP Flyer Red Battery Replacement
  1. HP Flyer Red Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Flyer Red Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Flyer Red Battery Replacement: stap 2, afbeelding 1 van 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Flyer Red Battery Replacement: stap 3, afbeelding 1 van 2 HP Flyer Red Battery Replacement: stap 3, afbeelding 2 van 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Flyer Red Battery Replacement: stap 4, afbeelding 1 van 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Anthony Ciotti
777 Reputatie
5 handleidingen geschreven
1Gids Commentaar
What do you do when the battery not charging but the laptop is working when directly plugged on power
liberty siegmann derera - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 2,748
