Ga door naar hoofdinhoud
HP Envy TouchSmart 15 Solid State Drive Replacement
Wat je nodig hebt
  1. HP Envy TouchSmart 15 Solid State Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Solid State Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: stap 3, afbeelding 1 van 2 HP Envy TouchSmart 15 Solid State Drive Replacement, Accessory Plate: stap 3, afbeelding 2 van 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Solid State Drive Replacement: stap 4, afbeelding 1 van 3 HP Envy TouchSmart 15 Solid State Drive Replacement: stap 4, afbeelding 2 van 3 HP Envy TouchSmart 15 Solid State Drive Replacement: stap 4, afbeelding 3 van 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: stap 5, afbeelding 1 van 2 HP Envy TouchSmart 15 Solid State Drive Replacement, Solid State Drive: stap 5, afbeelding 2 van 2
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  6. HP Envy TouchSmart 15 Solid State Drive Replacement: stap 6, afbeelding 1 van 2 HP Envy TouchSmart 15 Solid State Drive Replacement: stap 6, afbeelding 2 van 2
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ramon Villadonga
1.035 Reputatie
5 handleidingen geschreven
USF Tampa, Team 2-6, Sullivan Fall 2015 Lid van USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Leden
10 handleidingen geschreven
2Gids Commentaar
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
temidayoabayomizannu - Antwoord
Wht type of ssd i can insert here
Plz help me
Kavindra Danushka Rajapaksha - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 3,023
