Gereedschap
Onderdelen
Deze stap is niet vertaald. Help het te vertalen
Slide the switch to release the battery and remove it.
Remove the screw from the access panel. Gently lift and remove the panel.
Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
Remove the indicated screws to loosen the bottom casing.
Remove the two feet indicated to reveal the screws underneath.
Gently pry the edges to loosen the case.
Once loose, lift and remove the plastic casing to reveal the motherboard.
Lift and detach the wireless antenna cables.
Lift and de-route the wires from their tracks until you reach the display hinges.
Detach the two cables pictured. Lift the tab for the ribbon cable before pulling it out.
Remove the screws from each hinge.
Lift the hinges with pliers until they are perpendicular to the case.
Lift and remove the bottom of the laptop from the screen.
Lift the tabs in both the bottom corners and remove the screws beneath.
Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
Gently peel the digitizer away from the plastic border.
5 andere personen hebben deze handleiding voltooid.
4 Opmerkingen
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson, I have updated this page to included a link to the part on amazon.
