Ga door naar hoofdinhoud
HP Envy TouchSmart 15 Digitizer Replacement
Wat je nodig hebt
  1. HP Envy TouchSmart 15 Digitizer Replacement, Touch Screen/Digitizer: stap 1, afbeelding 1 van 1
    • Lay the laptop down with the bottom facing up.
  2. HP Envy TouchSmart 15 Digitizer Replacement: stap 2, afbeelding 1 van 1
    • Slide the switch to release the battery and remove it.
  3. HP Envy TouchSmart 15 Digitizer Replacement: stap 3, afbeelding 1 van 2 HP Envy TouchSmart 15 Digitizer Replacement: stap 3, afbeelding 2 van 2
    • Remove the screw from the access panel. Gently lift and remove the panel.
  4. HP Envy TouchSmart 15 Digitizer Replacement: stap 4, afbeelding 1 van 3 HP Envy TouchSmart 15 Digitizer Replacement: stap 4, afbeelding 2 van 3 HP Envy TouchSmart 15 Digitizer Replacement: stap 4, afbeelding 3 van 3
    • Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
  5. HP Envy TouchSmart 15 Digitizer Replacement: stap 5, afbeelding 1 van 3 HP Envy TouchSmart 15 Digitizer Replacement: stap 5, afbeelding 2 van 3 HP Envy TouchSmart 15 Digitizer Replacement: stap 5, afbeelding 3 van 3
    • Remove the screws to loosen the bottom casing.
    • Remove the two feet to reveal the screws underneath.
  6. HP Envy TouchSmart 15 Digitizer Replacement: stap 6, afbeelding 1 van 1
    • Gently pry the edges to loosen the case.
    • Once loose, lift and remove the plastic casing to reveal the motherboard.
  7. HP Envy TouchSmart 15 Digitizer Replacement: stap 7, afbeelding 1 van 2 HP Envy TouchSmart 15 Digitizer Replacement: stap 7, afbeelding 2 van 2
    • Lift and detach the wireless antenna cables.
    • Lift and de-route the wires from their tracks until you reach the display hinges.
  8. HP Envy TouchSmart 15 Digitizer Replacement: stap 8, afbeelding 1 van 1
    • Detach the two cables. Lift the tab for the ribbon cable before pulling it out.
  9. HP Envy TouchSmart 15 Digitizer Replacement: stap 9, afbeelding 1 van 2 HP Envy TouchSmart 15 Digitizer Replacement: stap 9, afbeelding 2 van 2
    • Remove the screws from each hinge.
    • Lift the hinges with pliers until they are perpendicular to the case.
    • Lift and remove the bottom of the laptop from the screen.
  10. HP Envy TouchSmart 15 Digitizer Replacement: stap 10, afbeelding 1 van 1
    • Lift the tabs in both the bottom corners and remove the screws beneath.
  11. HP Envy TouchSmart 15 Digitizer Replacement: stap 11, afbeelding 1 van 2 HP Envy TouchSmart 15 Digitizer Replacement: stap 11, afbeelding 2 van 2
    • Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
  12. HP Envy TouchSmart 15 Digitizer Replacement: stap 12, afbeelding 1 van 3 HP Envy TouchSmart 15 Digitizer Replacement: stap 12, afbeelding 2 van 3 HP Envy TouchSmart 15 Digitizer Replacement: stap 12, afbeelding 3 van 3
    • Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
    • Gently peel the digitizer away from the plastic border.
    • When installing the new one digitizer, press firmly around the edges.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Micah Kempf
260 Reputatie
1 Handleiding geschreven
4 opmerkingen
These directions are perfect. I was able to successfully change my digitizer in under an hour
Joe Russo - Antwoord
where do you get the digitizer?
Jacob - Antwoord
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson Odimgbe - Antwoord
Nevelson, I have updated this page to included a link to the part on amazon.
Micah Kempf - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 14,129
