Ga door naar hoofdinhoud
HP Envy 7640 Screen Replacement
Wat je nodig hebt
    1. HP Envy 7640 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 HP Envy 7640 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 HP Envy 7640 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
      • Open the printer by pushing upwards against the plastic tabs on the printer body's sides.
      • Remove the opening assist by pushing it toward the front of the printer with a nylon spudger.
      • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Envy 7640 Screen Replacement: stap 2, afbeelding 1 van 3 HP Envy 7640 Screen Replacement: stap 2, afbeelding 2 van 3 HP Envy 7640 Screen Replacement: stap 2, afbeelding 3 van 3
      • Place the T9 Torx screwdriver in the screw slot and turn counterclockwise to remove the two 12 mm screws that hold the screen manifold to the printer.
      • Push with minimal force to the right to dislodge the manifold from the printer body.
      • Lift the panel up and turn it over to reveal the green micro-controller board underneath.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Envy 7640 Screen Replacement: stap 3, afbeelding 1 van 2 HP Envy 7640 Screen Replacement: stap 3, afbeelding 2 van 2
      • Undo the two connectors by gently pulling them away from the board.
      • Remove the last connector by flipping the tab up and pulling away from the board while also pulling left.
      • Remove the five 6.5 mm screws from the board using the T6 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Envy 7640 Screen Replacement: stap 4, afbeelding 1 van 1
      • Insert the plastic opening tool into the space between the green board and the printer manifold and push downwards to dislodge the green board.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Envy 7640 Screen Replacement: stap 5, afbeelding 1 van 3 HP Envy 7640 Screen Replacement: stap 5, afbeelding 2 van 3 HP Envy 7640 Screen Replacement: stap 5, afbeelding 3 van 3
      • Peel back the tape that holds the screen in place.
      • Insert the plastic opening tool between the white screen backing and the screen to pry the screen backing from the adhesive that holds it in place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nicholas Sheffler
408 Reputatie
3 handleidingen geschreven
Cal Poly, Team S1-G2, Livingston Winter 2018 Lid van Cal Poly, Team S1-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G2
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 1,576
