Ga door naar hoofdinhoud
HP Envy 5660 Scanner Glass Replacement
Wat je nodig hebt
    1. HP Envy 5660 Scanner Glass Replacement, Scanner Glass: stap 1, afbeelding 1 van 1
      • Open the cartridge access area.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Envy 5660 Scanner Glass Replacement: stap 2, afbeelding 1 van 1
      • Remove the three 11.5 mm screws with a T10 bit.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Envy 5660 Scanner Glass Replacement: stap 3, afbeelding 1 van 3 HP Envy 5660 Scanner Glass Replacement: stap 3, afbeelding 2 van 3 HP Envy 5660 Scanner Glass Replacement: stap 3, afbeelding 3 van 3
      • Locate the cover hinge on the right side of the printer.
      • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Envy 5660 Scanner Glass Replacement: stap 4, afbeelding 1 van 2 HP Envy 5660 Scanner Glass Replacement: stap 4, afbeelding 2 van 2
      • Remove the 12 mm screws on the left side of the printer with a T10 bit.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Envy 5660 Scanner Glass Replacement: stap 5, afbeelding 1 van 2 HP Envy 5660 Scanner Glass Replacement: stap 5, afbeelding 2 van 2
      • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
      • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
      Vraag FixBot
      Voeg opmerking toe
    6. HP Envy 5660 Scanner Glass Replacement: stap 6, afbeelding 1 van 3 HP Envy 5660 Scanner Glass Replacement: stap 6, afbeelding 2 van 3 HP Envy 5660 Scanner Glass Replacement: stap 6, afbeelding 3 van 3
      • Pull the plastic side cover off of the printer.
      • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
      • Plastic opening tools or a metal spudger may also be used.
      Vraag FixBot
      Voeg opmerking toe
    7. HP Envy 5660 Scanner Glass Replacement: stap 7, afbeelding 1 van 1
      • Remove the five 11.5 mm screws located at the bottom of the scanner.
      • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
      • The top of the scanner will now easily pull off.
      Vraag FixBot
      Voeg opmerking toe
    8. HP Envy 5660 Scanner Glass Replacement: stap 8, afbeelding 1 van 2 HP Envy 5660 Scanner Glass Replacement: stap 8, afbeelding 2 van 2
      • Pry the old scanning glass up with a metal spudger.
      • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ryan Steakley
790 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G6, Livingston Winter 2018 Lid van Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Leden
10 handleidingen geschreven
1Gids Commentaar
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
Rich Monell - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 31
Altijd: 2,036
