Inleiding
To make sure that replacement of the audio jack is necessary follow these troubleshooting steps before using this guide.
Wat je nodig hebt
Using a Phillips #00 screwdriver, remove the two Phillips PM 1.4×3.2mm screws located next to the charging port.
Place the suction cup on the lower right corner of the tablet display glass, making sure to place the suction cup inside the edges of the border of the display glass.
Insert a plastic pick in between the display and the tablet case. Then use a plastic removal tool to separate the display further.
Pull on the suction cup while using the prying tool to separate the display from the tablet.
Één andere persoon heeft deze handleiding voltooid.
