Ga door naar hoofdinhoud
HP EliteBook x360 830 G7 Solid State Drive Replacement
Wat je nodig hebt
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: stap 1, afbeelding 1 van 2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: stap 1, afbeelding 2 van 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: stap 2, afbeelding 1 van 1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: stap 3, afbeelding 1 van 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: stap 3, afbeelding 2 van 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: stap 3, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: stap 4, afbeelding 1 van 1
    • Gently pull the SSD free from the M.2 socket.
Conclusie
Emily Kaplan
217 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 91
Altijd: 1,580
