Ga door naar hoofdinhoud
HP EliteBook 8560w Keyboard Replacement
Wat je nodig hebt
  1. HP EliteBook 8560w Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP EliteBook 8560w Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery out.
  3. HP EliteBook 8560w Keyboard Replacement, Back Panel: stap 3, afbeelding 1 van 2 HP EliteBook 8560w Keyboard Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: stap 5, afbeelding 1 van 2 HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: stap 5, afbeelding 2 van 2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Keyboard Replacement: stap 6, afbeelding 1 van 3 HP EliteBook 8560w Keyboard Replacement: stap 6, afbeelding 2 van 3 HP EliteBook 8560w Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Keyboard Replacement: stap 7, afbeelding 1 van 2 HP EliteBook 8560w Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Keyboard Replacement, Keyboard: stap 8, afbeelding 1 van 1
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Keyboard Replacement: stap 9, afbeelding 1 van 3 HP EliteBook 8560w Keyboard Replacement: stap 9, afbeelding 2 van 3 HP EliteBook 8560w Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Keyboard Replacement: stap 10, afbeelding 1 van 3 HP EliteBook 8560w Keyboard Replacement: stap 10, afbeelding 2 van 3 HP EliteBook 8560w Keyboard Replacement: stap 10, afbeelding 3 van 3
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 27
Altijd: 1,402
