Ga door naar hoofdinhoud
HP Deskjet 1000 J110a Paper Control Sensor Replacement
Wat je nodig hebt
    1. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: stap 1, afbeelding 1 van 3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: stap 1, afbeelding 2 van 3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: stap 1, afbeelding 3 van 3
      • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
      Vraag FixBot
      Voeg opmerking toe
    2. HP Deskjet 1000 J110a Paper Control Sensor Replacement: stap 2, afbeelding 1 van 3 HP Deskjet 1000 J110a Paper Control Sensor Replacement: stap 2, afbeelding 2 van 3 HP Deskjet 1000 J110a Paper Control Sensor Replacement: stap 2, afbeelding 3 van 3
      • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Deskjet 1000 J110a Paper Control Sensor Replacement: stap 3, afbeelding 1 van 1
      • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
      Vraag FixBot
      Voeg opmerking toe
    1. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: stap 4, afbeelding 1 van 3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: stap 4, afbeelding 2 van 3 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: stap 4, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Locate the paper control sensor.
      • You can find the sensor, with the back of the printer facing you, on the right, and in front of the main circuit board. The paper control sensor will also be attached to a small circuit board. You will be replacing this circuit board.
      • Locate and unplug the connector which connects the sensor board to the main circuit board.
      • Use tweezers if unplugging by hand is too difficult.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Deskjet 1000 J110a Paper Control Sensor Replacement: stap 5, afbeelding 1 van 2 HP Deskjet 1000 J110a Paper Control Sensor Replacement: stap 5, afbeelding 2 van 2
      • Locate and remove the 8mm screw with a screwdriver and the T10 torx bit, then remove the paper control sensor board.
      • In this picture, the main circuit board is removed. It is not necessary to remove the main circuit board unless the paper control sensor is not the only part being replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Colin Tourjee
806 Reputatie
4 handleidingen geschreven
USF Tampa, Team S5-G3, Passmore Spring 2018 Lid van USF Tampa, Team S5-G3, Passmore Spring 2018
USFT-PASSMORE-S18S5G3
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 61
Altijd: 2,993
