Ga door naar hoofdinhoud
HP Compaq nc6400 Screen Replacement
Wat je nodig hebt
  1. HP Compaq nc6400 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off and unplug laptop.
  2. HP Compaq nc6400 Screen Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
  3. HP Compaq nc6400 Screen Replacement: stap 3, afbeelding 1 van 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    10.8 volt ????
    OK ?
    Gilbert Baum - Antwoord
    the volt is 10.8,,?
  4. HP Compaq nc6400 Screen Replacement: stap 4, afbeelding 1 van 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
  5. HP Compaq nc6400 Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
  6. HP Compaq nc6400 Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
  7. HP Compaq nc6400 Screen Replacement: stap 7, afbeelding 1 van 3 HP Compaq nc6400 Screen Replacement: stap 7, afbeelding 2 van 3 HP Compaq nc6400 Screen Replacement: stap 7, afbeelding 3 van 3
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
  8. HP Compaq nc6400 Screen Replacement: stap 8, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
  9. HP Compaq nc6400 Screen Replacement: stap 9, afbeelding 1 van 1
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
  10. HP Compaq nc6400 Screen Replacement: stap 10, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 10, afbeelding 2 van 2
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
  11. HP Compaq nc6400 Screen Replacement: stap 11, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
  12. HP Compaq nc6400 Screen Replacement: stap 12, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 12, afbeelding 2 van 2
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
  13. HP Compaq nc6400 Screen Replacement: stap 13, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 13, afbeelding 2 van 2
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Luis Vazquez
401 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-6, Forte Fall 2013 Lid van Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Leden
5 handleidingen geschreven
1Gids Commentaar
Nicely done. Thanks?
Peter Q. - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 5,484
