Ga door naar hoofdinhoud
HP Compaq nc6400 Screen Replacement
Wat je nodig hebt
  1. HP Compaq nc6400 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off and unplug laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Compaq nc6400 Screen Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Compaq nc6400 Screen Replacement: stap 3, afbeelding 1 van 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Compaq nc6400 Screen Replacement: stap 4, afbeelding 1 van 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Compaq nc6400 Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • Remove the four 1.2mm Philips #1 screws attaching the plastic cover to the monitor.
    • The screws may have a small, black plastic cover that lays flush with the screen. Remove these using a pointed tool such as the spudger or philips head screwdriver by prying them out.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Compaq nc6400 Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 1.2 Philips #1 screws attaching the face plate to the body.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Compaq nc6400 Screen Replacement: stap 7, afbeelding 1 van 3 HP Compaq nc6400 Screen Replacement: stap 7, afbeelding 2 van 3 HP Compaq nc6400 Screen Replacement: stap 7, afbeelding 3 van 3
    • Pry up the plastic screen cover using a pry tool.
    • Keeping the pry tool under the trim, slide it around the entire screen until the the cover has completely detached from the base.
    • You might need to slide the display clip on the top of the screen in order to fully remove the plastic cover.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Compaq nc6400 Screen Replacement: stap 8, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 1.2 Philips #1 screws holding down the sensor board at the bottom of the monitor.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Compaq nc6400 Screen Replacement: stap 9, afbeelding 1 van 1
    • Remove the right-most 1.2mm Philips #1 screw on the bottom of the monitor.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Compaq nc6400 Screen Replacement: stap 10, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 10, afbeelding 2 van 2
    • Without lifting the bottom of the monitor, gently flip the screen and lay it face down on the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Compaq nc6400 Screen Replacement: stap 11, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the tape holding down the video cable to the monitor.
    • Gently pull out the video cable from the monitor.
    Vraag FixBot
    Voeg opmerking toe
  12. HP Compaq nc6400 Screen Replacement: stap 12, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 12, afbeelding 2 van 2
    • Remove the monitor's power cable from the sensor board.
    • This is the cable on the farthest right of the sensor board.
    Vraag FixBot
    Voeg opmerking toe
  13. HP Compaq nc6400 Screen Replacement: stap 13, afbeelding 1 van 2 HP Compaq nc6400 Screen Replacement: stap 13, afbeelding 2 van 2
    • Once all cables attaching the casing to the monitor have been disconnected, remove the entire screen from the computer and lay it on a flat surface.
    • Remove the four 1.2 Philips #1 screws attaching the bezel to the right side of the monitor.
    • Attach bezel to replacement screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Luis Vazquez
401 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-6, Forte Fall 2013 Lid van Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Leden
5 handleidingen geschreven
1Gids Commentaar
Nicely done. Thanks?
Peter Q. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 5,907
