Ga door naar hoofdinhoud
HP Compaq nc6400 RAM Replacement
Wat je nodig hebt
  1. HP Compaq nc6400 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off and unplug laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Compaq nc6400 RAM Replacement: stap 2, afbeelding 1 van 1
    • Locate the battery lock below the battery labeled one.
    • Slide the lock all the way to the left to release the left lock of the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Compaq nc6400 RAM Replacement: stap 3, afbeelding 1 van 1
    • Locate the lock labeled two at the bottom right corner below the battery.
    • Slide and hold the lock to the left.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Compaq nc6400 RAM Replacement: stap 4, afbeelding 1 van 1
    • Once both the battery locks are unlocked, slide the battery out to remove.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Compaq nc6400 RAM Replacement, RAM: stap 5, afbeelding 1 van 2 HP Compaq nc6400 RAM Replacement, RAM: stap 5, afbeelding 2 van 2
    • Remove the 1.2 Philips #1 screw holding down the RAM cover to the body.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Compaq nc6400 RAM Replacement: stap 6, afbeelding 1 van 1
    • Once the screw is removed, use a spudger to pry open the case covering the RAM chip.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Compaq nc6400 RAM Replacement: stap 7, afbeelding 1 van 2 HP Compaq nc6400 RAM Replacement: stap 7, afbeelding 2 van 2
    • Use a plastic opening tool to pull back the white clip holding the RAM chip in place.
    • Once the plastic opening tool has disengaged the clip from the RAM chip, keep the plastic opening tool locked into place.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Compaq nc6400 RAM Replacement: stap 8, afbeelding 1 van 1
    • With a second plastic opening tool,repeat the above process
    • After both plastic opening tools have been locked in place, the RAM chip should pop out about 1/4 of a inch.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Compaq nc6400 RAM Replacement: stap 9, afbeelding 1 van 2 HP Compaq nc6400 RAM Replacement: stap 9, afbeelding 2 van 2
    • The RAM chip is susceptible to static electricity. Before grabbing the RAM chip, make sure you have discharged the electricity from your hands by touching a metal surface other than your computer.
    • Grab the RAM chip with your thumb and index finger
    • Carefully pull the RAM chip out
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Luis Vazquez
401 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-6, Forte Fall 2013 Lid van Cal Poly, Team 14-6, Forte Fall 2013
CPSU-FORTE-F13S14G6
5 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 30
Altijd: 4,869
